viscosity
Old   April 11, 2004, 00:42
Default viscosity
Jane
Hi,all Now I have a problem, i want use the in-consitant viscosity, i want use subrutine to define it. so i open the molecular Properties > molecular viscosity > ueser > define the user code. but when i write the problem file, it cannot be written correctly it is said " parameters not set for non-constant viscosity."
what is matter with it?
thank you ! jane
turbulent viscosity limited to viscosity ratio of Hua FLUENT 7 September 27, 2019 06:42
turbulent viscosity limited to viscosity ratio... frank FLUENT 19 December 15, 2015 22:54
turbulent viscosity limited to viscosity ratio Elizabeth FLUENT 13 December 16, 2014 08:57
Turbulent viscosity Limited to viscosity ratio Adrian FLUENT 12 September 21, 2011 04:22
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 20:34
