July 6, 2004, 10:11 |
My patch causes a discontinuity in the mesh
I have a 3D model done with a patch (shells) that I extruded in cylindrical coordinate. I ran the analysis, but I saw in the results that there is a discontinuity in the flow where the patch is, as if the patch was a wall. In the cells list, I have fluid cell except for the patch. What can I do to remove this discontinuity?
Thanks. |
July 6, 2004, 11:44 |
Re: My patch causes a discontinuity in the mesh
Sounds like you extruded to both sides of the patch? (If not, your patch (shells) are against a wall, and there should be a boundary layer)
So after extrusion, did you do a VMERG to link the two meshes together? |
July 6, 2004, 11:56 |
Thank you! It was that! I did not do the VMERG.
Thanks a lot. |
July 6, 2004, 12:00 |
But now I have collapsed faces, what can I do?
July 7, 2004, 07:41 |
sounds like you have now some prisms in the center of your duct (due to extrusion and vmerg) put these cells into cset and: cflip cset,,,prism this should work
July 7, 2004, 07:45 |
Yes it works. Thanks!
Patch end points mesh motion and movingWallVelocity | pbo | OpenFOAM Running, Solving & CFD | 14 | October 4, 2023 11:20 |
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH | mkraposhin | OpenFOAM Running, Solving & CFD | 3 | September 4, 2011 09:42 |
Moving interface patch using mesh subsets | lr103476 | OpenFOAM Running, Solving & CFD | 0 | January 10, 2008 16:14 |
[Technical] Coupled cells or mesh discontinuity | sylvain91 | OpenFOAM Meshing & Mesh Conversion | 0 | September 14, 2006 07:43 |
Patch mesh export | ariorus | OpenFOAM | 3 | March 7, 2006 05:41 |
