Display in Windows
Old   April 8, 2005, 00:32
Default Display in Windows
Anthony
Hello all. I am new to Star-CD and am having problems with getting the display to work properly in the Windows XP Pro environment. I have installed the version of XVision that came with the software; however, I keep getting an error message when I try to open any of the products available from the Star-Launch screen such as Pro-Star, etc. The error says "Error attempting to open X display". It seems like this must be an environment variable that needs to be set but I have tried and tried without any success to configure it properly. Any help that can be offered would be much appreciated. Thanks in advance.
Anthony
Old   April 8, 2005, 03:15
Default Re: Display in Windows
Anton Lyaskin
Try to start XVision manually before launching something from StarLaunch
Old   April 8, 2005, 04:37
Michele
Try to go to the Vision Communications applet in the Controls Panel. Select the Transports tab. Highlight the TCP-Unix option and press the Properties button. Change the Availability Status to Enable this transport. Also ensure that Include this transport in automatic selection is checked.
You can also try to read the STAR-CD FAQ section about Display problems.
Old   April 30, 2005, 10:31
Fred
Hi Anthony,
You should open exceed from hummingbird b4 opening prostar/proam
I think this should help
Regards Fred
How to display dT/dx? Williams FLUENT 8 December 6, 2018 19:57
problems with Fluent display windows chris FLUENT 3 January 7, 2016 10:44
Display static pressure and pathline isame windows GregC FLUENT 1 October 18, 2007 08:31
display options Jakub FLUENT 2 October 5, 2005 07:39
Graphics Display Andrew FLUENT 3 June 10, 2003 06:24
