Error when using subroutine in STARCD 3.22
Old   May 9, 2005, 23:17
Default Error when using subroutine in STARCD 3.22
xhliu1
Hello everyone! Here I have one problem when using subroutine in Star-CD 3.22.That is:
D:\Program Files\CD adapco\STAR-CD\..\wingnu\msys\1.0\bin\sh.exe --login -c "/D/PROGRA~1/CDADAP~1/STAR-CD/bin/star ndt06 " PNP: Initialized [2005-05-10-11:05:40] Automatic Sequential Automatic Parallel analyzer. PNP: Allocated "ndt06,1" resource (1 process). PNP: Assigned "ndt06,1" to STAR solver (1 process). PNP: Analyzing User coding in "ufile" directory. PNP: compiling /D/Program Files/CD adapco/Absoft70/bin/f77 -O2 -f -v -N3 -N26 -N25 -Q101 !Q19 -c posdat.f -o windows-x86-absoft_8.2a-dso/posdat.obj PNP: /D/PROGRA~1/CDADAP~1/STAR-CD/bin/star: /D/Program: No such file or directory PNP: ***ERROR*** Compilation error in user file "ufile/posdat.f". PNP: ==> Please check the compilation error messages.
If you know what is the problem and how I can solve it, Please help me!!
Thanks alot!!
Liu
Old   May 10, 2005, 04:27
Default Re: Error when using subroutine in STARCD 3.22
Tim
The answer is in your question.
It is failing to compile your user coding because it, or something to do with it, doesn't exist.
Old   May 11, 2005, 14:26
kevin
actually you have two problems...
1) I am going to guess that your Absoft Fortran compiler is installed in a path with spaces...which means your ABSOFT variable is set to that path with spaces...and I think the compilation is failing because of that. Try installing the compiler to a path with no spaces and setting the ABSOFT variable to point to the new location.
2) You appear to be using Absoft ProFortran 7.0...as indicated in the documentation, the supported version is v 8.2.
kevin
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
Error in subroutine FNDVAR Mickel CFX 7 July 19, 2006 08:15
WAVE-STARCD/1D-3D Coupling Error Charlie Siemens 5 December 22, 2005 04:18
Error in subroutine FNDVAR pi CFX 5 July 5, 2004 18:41
Error in subroutine FNDVAR San Chang CFX 0 May 24, 2004 17:54
