star cd and xvision
Old   September 6, 2005, 08:37
Default star cd and xvision
akin
can anyone tell me how to use xvision with star-cd
Old   September 7, 2005, 02:59
Default Re: star cd and xvision
dams
I am interested in that one too. I have newer been able to use xvision together with star-cd. It can't open the display...
Old   September 7, 2005, 16:08
staruser
XVision is used since pro-STAR is written in Motif. You can also use other toold like Exceed Hummingbird. If you get the warning/error messag the the display cannot be opened you need to adjust your settings for XVision. I don't have pro-STAR in from of me, so it might not be exactly right what I suggest... You should close XVison, go to system settings and open XVision. In one of the panels there are options regarding transport. You need to allow TCP/IP transport. When you restart XVision you should be able to start pro-STAR.
It is mentioned in the installation notes vor 3.150 or in the FAQs in 3.24.
Hope this helps.
Old   September 11, 2005, 13:04
marc
does anybody resolve that problem? I tried to set TCP/IP in the ANSI Emulator, but it did not work
Old   September 26, 2005, 05:31
tonggang
install exceed it have xvision with star-cd
Old   October 27, 2005, 21:48
tyrouser
About Xvision I have a problem with it during installation. It shows "cannot install xvision". Therefore I can not use pro-star after the installation. Could anyone tell me how to install xvision in V3.24?
Xvision problem Elyor Siemens 1 June 14, 2007 02:36
Xvision Probelm Sid Siemens 2 May 17, 2006 06:44
Xvision - profile is already running Javidan Ahmad Siemens 2 December 4, 2003 19:29
