Weghted averages along lines
Old   April 17, 2007, 03:26
Default Weghted averages along lines
Ale
I would like to compute mass-weighted averages and area-weighted averages along lines (e.g. arcs, or straight lines) laying on a section which is not oriented as the grid, so that the section cuts several layers of exahedral cells.
Could you please tell me what's the most efficent way to do that in StarCD, or suggest a postprocessing software that could do that?
Thank you very much indeed.
Regards,
Ale
Old   April 19, 2007, 12:03
Default Re: Weghted averages along lines
ping
You can do this in proSTAR:
1. create some shell cells where you want the results - e.g. create a spline where you want the results, loop over its v's to create line cells, then extrude these into a thin line of shells.
2. load your results into the fluid cell post registers and do any calc OPERATIONS to mass average or whatever.
3. map these results onto the shell cells using command PMAP (you could alternatively also put lots of vertices evenly along the spline and map into these - depends what you really want)
4. CSET the shells or v's and plot or SUMM or whatever
Old   April 20, 2007, 03:36
Ale
Thank you Ping, I will try this way.
Regards,
Ale
Averages in an homogeneous direction luiz OpenFOAM Post-Processing 7 March 12, 2023 09:00
Weighted Averages Disagree Ryan FLUENT 3 February 8, 2008 15:55
Radial averages smillerhh FLUENT 1 November 8, 2006 07:54
Problem with integrals and averages if backflow?? Amit FLUENT 0 October 19, 2006 18:54
cicumferential averages vaishali FLUENT 0 August 13, 2006 13:21
