Compilation
Old   September 9, 2008, 06:20
Default Compilation
alessio
Dear all,
I am trying to use starcd with user defined subroutines. But we get an error:
PNP: compiling /share/apps/absoft/bin/f90 -w -fPIC -YCOM_NAMES=LCS -YEXT_NAMES=LCS -YEXT_SFX=_ -B19 -cpupteron -m64 -c Uposdat.f -o linux64_2.4-absoft_9.0a-gcc_4.1.1-glibc_2.2.5-dso/Uposdat.o PNP: ***ERROR*** Failed to generate user coding dynamic shared object "ufile/linux64_2.4-absoft_9.0a-gcc_4.1.1-glibc_2.2.5-dso/libstarusr.so". PNP: ==> Please check the dynamic shared object generation error messages.
Do you know where I can find the error messages for the dynamic shared object generation?
Regards Alessio
Old   September 18, 2008, 03:32
Default Re: Compilation
Philip Jones
I bet that the problem is in the file being called Uposdat.f and has a subroutine called posdat inside it.
STAR-CD has an archive of dummy routines for user coding, when it compiles it removes the dummys by matching the name, so if you supply posdat.f it removes posdat.o from the archive and then builds using the remainder of the archive and your new object.
If you have subroutine posdat in file Uposdat.f then it will leave posdat.o in the archive and so you now have multiple definitions of posdat and it fails.
On my machine I get this message:
PNP: Building New dynamic shared object "ufile/linux64_2.4-pgf90_6.2-gcc_4.1.1-glibc_2.2.5-dso/libstarusr.so" PNP: packing ufile/linux64_2.4-pgf90_6.2-gcc_4.1.1-glibc_2.2.5-dso/Uposdat.o PNP: packing ufile/linux64_2.4-pgf90_6.2-gcc_4.1.1-glibc_2.2.5-dso/libstarusr.a PNP: ufile/linux64_2.4-pgf90_6.2-gcc_4.1.1-glibc_2.2.5-dso/libstarusr.a(posdat.o): In function `posdat_': PNP: posdat.o(.text+0x0): multiple definition of `posdat_'
UDF COMPILATION... venkatesh4386@gmail.com FLUENT 2 December 1, 2008 08:58
UDF COMPILATION... venkatesh4386@gmail.com FLOW-3D 0 November 8, 2008 11:22
UDF COMPILATION T.Hariharanath FLUENT 2 July 25, 2005 11:47
UDF compilation: need VC++? Biga FLUENT 3 November 6, 2004 13:34
udf compilation jy FLUENT 0 August 10, 2000 09:39
