prism layers at free surface.
Old   September 22, 2008, 12:44
Default prism layers at free surface.
MAB
I need to refine mesh at the free surface interface between water and air. Any idea how to refine mesh at free surface. Thanks
Old   September 22, 2008, 16:00
Default Re: prism layers at free surface.
Balduin Bankerotti
Just define 2 regions and enable the "grow from interface" option.
Old   September 22, 2008, 16:58
MAB
Thanks Balduin Bankerotti!!!
Could you please give a hint, how to define two regions. Thanks again
Old   September 23, 2008, 01:17
Balduin Bankerotti
Check the "Heat Exchanger Unit Meshing Tutorial" tutorial.
Old   September 23, 2008, 03:29
Bob
Why do you want prism layers at the free surface? There isn't much point in splitting the domain in two and then re-meshing, it is just making more work for yourself, why not just use a mesh volume source and refine within it?
Old   September 23, 2008, 04:33
Name
Use volume sources where you have free surface to refine your mesh..
Old   September 23, 2008, 05:46
MAB
Thanks Bob!!! Is there any tutorial about mesh volume source
ICEMCFD creates irregular surface layers ? ingear CFX 1 April 10, 2006 14:37
refine surface layers with icem Andreas CFX 0 October 24, 2005 04:02
free RANS code with free surface ability Lou jing Main CFD Forum 1 July 11, 2003 14:43
[surface tension effect at free-surface ?] name Main CFD Forum 1 September 21, 2001 09:54
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 16:14
