Multi region meshing
Old   March 16, 2012, 02:18
Default Multi region meshing
noob@cfd is on a distinguished road
Hi everyone,
I have been wanting to use the import wings toolbox. The bounding box created by the mesher is not big enough for its boundaries to be set with boundary conditions. Another region has to be created which encompasses the bounding box. I have been told to fill this region up with polyhedral cells. However, I am not able to make out how carry out the meshing on the outer box, as in
Do I mesh the second region separately and then combine the region with an interface? When I do that I get totally wrong results. Also get a warning no intersection found.
Or should I merge the regions first and then do the meshing?
Please help me out.
Regards
noob@cfd is offline   Reply With Quote
Old   March 20, 2012, 04:45
Jimmy
Jimmy123 is on a distinguished road
Hello, I'm also a noob but I'm working on a similar problem right now. So correct me if I'm wrong because I need every help I can get. I would say that you first need to get the regions separated by an interface. One way of doing this is to first combine your part with the bounding part into one, and then use split by surface topology. Then the interface will appear when you assign the parts to different regions. In order to get a conformal mesh between the two regions you use one mesh continuum for both regions. And I think that it is only polyhedral and tetrahedral meshes that can produce a conformal mesh. But if you are using StarCCM 7.02 I have heard that you can use some kind of mapped interface and hence use different meshes.
Hope this helped you!
Good luck /Jimmy
Jimmy123 is offline   Reply With Quote
Old   March 26, 2012, 12:32
Dan Hamilton
DanHamilton is on a distinguished road
It's pretty important that you spend the time up front to understand how interfaces work in STAR-CCM+ - it'll save you loads of hair-pulling in the future. You need to get all of your interfaces set up before you mesh - the easiest way to do this is through use of the boolean operations at part or region level. I'd recommend looking through the vast tutorial docs.
You can have different mesh continua for your different regions. It generally doesn't matter if the interface is conformal - if your face sizes on either side are similar, you'll get a good interface. The new direct map interfaces in 7.02 are currently only valid for fluid/solid interfaces.
Regards
Dan
DanHamilton is offline   Reply With Quote
[snappyHexMesh] Multi Region Meshing bruce OpenFOAM Meshing & Mesh Conversion 12 July 31, 2013 10:09
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
