Error when I add a porous region
Old   May 30, 2012, 05:31
Default Error when I add a porous region
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
I specified some boundaries as a porous region. But when I try to run the simulation, I get an error. The error says " invalid fvregion".
Does anyone have any idea about the error?
Thanks in advance
siara817 is offline   Reply With Quote
Old   May 31, 2012, 00:58
bryan he is on a distinguished road
I'm a little confusing about that "you set boundaries as porous region". Only the whole region can be difined as a porous region.
I guess you set the boundary as porous baffle, right?
If you did that, there is a restriction that the regions between this boundary should be in the same continuum, which means they should share the same "physica".
bryan he is offline   Reply With Quote
Old   May 31, 2012, 04:43
siara817's Avatar
The problem was caused by the mesher. It was meshing both regions simultaneusly, so the second region was removed by the mesher. To solve the problem, I clicked the item Continua/Mesh and in the mesh properties I ticked the item per-region meshing. The problem was solved.
Porous Region within Open Air "Wind Tunnel" Region Interfacing pkirchner STAR-CCM+ 10 March 27, 2014 19:10
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
How do you set up a porous region charltonjames STAR-CCM+ 13 August 13, 2011 18:29
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
