Mesh stretching starccm+
Old   June 9, 2012, 06:16
Default Mesh stretching starccm+
rawe666 is on a distinguished road
Hi all,
I am quite new to starccm+ program. What I am trying to do is, generating 2D mesh geometry. I have a simple rectangular geometry. I create it from CAD section in starccm+, mesh it in 3D, then convert it to 2D geometry. I want to stretch my grid points in x- and y- directions. And also I want to use rectangular meshes. Which meshing models should I use and how do I stretch my grid points?
Regards
rawe666 is offline   Reply With Quote
Old   June 20, 2012, 05:59
KHB
lava12005 is on a distinguished road
You can use the trimmer mesh model for the rectangular mesh.
I don't think Star-CCM+ can do the stretching that u want (if I get your point).
Trimmer mesh will generate rectangular, but stretching is always a factor of 2.
Or maybe there is a way from the expert here?
Maybe you can just cluster the small box in the area where u want the flow to be resolved and high gradient existance.. and bigger box on the rest..
lava12005 is offline   Reply With Quote
Old   June 20, 2012, 08:42
Ryne Whitehill
rwryne is on a distinguished road
I hardly ever use the trimmer mesher, but I do know that the volumetric controls for the trimmer mesh has an "isotropic" and "anisotropic" value that you can use to control growth in X and Y.
I assume you can do this without a volumetric control, but do not know how.
rwryne is offline   Reply With Quote
Old   June 20, 2012, 08:52
KHB
Yes, you can do volumetric control and choose anisotropic.
This will help you to locate more points in certain direction, for example when doing ship simulation, one would like to have more points in the vertical direction between the air and water to keep a good resolution at the interface. So we can create a volumetric control near the surface of water, and use the anisotropic option for trimmer mesh and specify the size on vertical mesh direction.
But as far as I know, the jump from let say the smallest dx (say dx1) to the next smallest dx (say dx2) is by the factor of two. So its always dx2 = 2*dx1.
Old   June 20, 2012, 09:31
Ryne Whitehill
Ah, I may have misunderstood the original inquiry. I understand now, thanks for clarification.
Old   June 25, 2012, 04:08
Thank you for your reply. Trimmer --> volumetric control --> anisotropic options allow me to locate more points in specific directions. It is correct. But i couldnt find strecthing factor which I can define. I came to know , you can create one table that contains the coordinates of the points and the number of cells. Then you can create your mesh by choosing the table. However,I have not tried that yet.
Old   June 29, 2012, 11:08
Nick
NickFSI is on a distinguished road
rawe666, I've been struggling to do the same thing, which I thought was a fairly simple task. Have you had any success with the table method you mentioned?
NickFSI is offline   Reply With Quote
Old   July 2, 2012, 09:26
NickFSI, i did not try it. I created my mesh with two volumetric control volumes. In one volume, mesh is finer than the other. It seemed to be easer and it is fine for a now for my case. Good luck!
2d mesh, grid stretching, mesh grading, mesh stretching, starccm+
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
