February 10, 2013, 09:34 |
Gamma - ReTheta Transition Model
anonymous
Rep Power: 13 |
I am trying to use the Gamma - ReTheta Transition Model to predict seperation and transition on the T106 Turbine Blade Geometry. I have switched the model on using the default settings and it gives ok results. I however want to change it so that it matches better. There are a number of constants that you can change however I am not sure what each of these does. The Starccm help files also doesnt give any indication. Does anyone have an explanation of what they do. I have read up on the model so I know roughly how it works. Thanks |
gamma, retheta, transition model |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Viscosity ratio in gamma-theta transition model based on k-w sst turb model | Qiaol618 | Main CFD Forum | 8 | June 9, 2012 06:43 |
SSt k-omega in gamma-Retetha transition model | mb.pejvak | Main CFD Forum | 3 | June 1, 2012 05:05 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
where to set CFX Transition Model? | steven | CFX | 6 | January 17, 2007 11:19 |
