Cavitation on water pump impeller
Like Tree1Likes
  • 1 Post By nyquisty
Old   March 4, 2013, 21:28
Default Cavitation on water pump impeller
nyquisty is on a distinguished road
I am trying to simulation the cavitation on the back of a water pump impeller. I select VOF model. Create three phases, H20, H2O gas and air. The multiphase interaction are H2O-H2O(G) and H20-air. Actually, I want to create H2O(G)-air for 2nd interaction, but star-ccm+ cannot do that. I don't know why.
The model is reasonable? Could I say that if the fraction of air is not 0, the cavitation would happen?
Richy likes this.
nyquisty is offline   Reply With Quote
Old   March 29, 2013, 12:11
mic
mic is on a distinguished road
Hi nyquisty, I have experience on cavitating water pumps impeller with CFX and Simerics.
...and to set up and run such a simulation is Simerics is much more easy than in any other CFD code I happened to bump in. And the results are absolutely good compared to experimental tests
mic is offline   Reply With Quote
cavitation, water pump
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
cavitation impeller centrifugal pump mino2006 CFX 2 September 19, 2007 12:16
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
