1D mesh with StarCCM+
Old   October 9, 2013, 05:27
Default 1D mesh with StarCCM+
Thomas
thomasg is on a distinguished road
I need some help on how using StarCCM+ to create a 1D mesh to study, at first, a flow in a duct.
I have created a 3D part and try to mesh only in the x-axis but the problem is that with trimmer, for example, the other surfaces are meshed too and so the volume mesh is 3D.
Thanks for helping.
Thomas.
thomasg is offline   Reply With Quote
Old   October 12, 2013, 15:11
cfdguy's Avatar
cfdguy is on a distinguished road
Hi Thomas,
I'd start with a Trimmer only mesh continua with a given base size. E.g.: 1mm.
Then, create a rectangular channel in x-axis, where the cross section at x0 (inlet) and x1 (outlet) are 1mm^2. Thus, if the channel has 100mm it will have 100 points.
The other channel faces (y0, y1, z0 and z1) set as symmetry. Now you have a 1D problem being solved with a 3D mesh.
Cheers,
cfdguy
** Every rose has its thorn **
PS: Please watch this Youtube channel.
cfdguy is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
[Other] Problems with starccm mesh AndTen OpenFOAM Meshing & Mesh Conversion 1 February 23, 2010 04:43
