October 23, 2013, 16:30 |
Vof waves in star ccm+
David
Rep Power: 14 |
Hi all
Since the generation of wave is build in star ccm+ and for some reason, it is not that easy to monitor the wave elevation time history at some certain point in the wave field. Thus there's few investigation into the wave generating ability of star ccm+( I mean by using the build in vof wave method). Recently, I've carried out some simulation about numerical wave tank using star ccm+ and found that wave generated using first order wave is not good( the time history of the wave elevation at certain point is not stable compared with the result gain by FLUENT). Is there anyone else who has experienced such problem? |
October 25, 2013, 11:10 |
Ryan Coe
Rep Power: 15 |
Could this be because 1st-order waves are physically unrealistic and therefore not supported by the governing equations being enforced in the simulation (this doesn't explain why Fluent would give better result)?
Ryan |
October 25, 2013, 11:20 |
David
Rep Power: 14 |
Hi Ryan
In my view, it is ture that linear wave are physically unrealistic and for those CFD solve the problem based on N-S equation, it is not possible to generate exact first order linear wave, thus the result calculated by FLUENT is some more like 2nd order wave. However, it should not make the result unstable, I mean there should not be too much difference between each wave trough or crest. |
October 30, 2013, 08:30 |
Ryan Coe
Rep Power: 15 |
I suppose that the most likely culprit for a changing waveform at a set location would be reflections.
Ryan |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 22:15 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
error in star ccm | maurizio | Siemens | 3 | October 16, 2007 05:17 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
