Simple Pressure Drop Calculation
Like Tree1Likes
  • 1 Post By MukeshKarabash
Old   April 13, 2014, 14:28
Default Simple Pressure Drop Calculation
MukeshKarabash is on a distinguished road
Hi everybody,
I am trying to calculate the pressure drop in a simple pipe flow. It is basicly hot air flowing from compressor through a 1,5 meter long pipe which is opening to atmosphere. I have the mass flow rate of the inlet and the ambient pressure (atmosphere). In star ccm+ (i am not very familiar with the software by the way) I choose mass flow inlet as the inlet boundary type and enter the mass flow rate value, I choose the pressure outlet as the outlet boundary type. But the next steps i cannot figure out myself. How should i configure the outlet boundary pressure value and how should i set the initial conditions? Also about creating a report, which report should i creat to see the pressure drop? I really need help on this one.
MukeshKarabash is offline   Reply With Quote
Old   April 14, 2014, 16:06
DaveyBaby
DaveyBaby is on a distinguished road
Hi!
1.) Make two "Surface Average" reports of the pressure at an axial distance X apart.
2.) Search "Referencing Field Functions" and "Using Reports as Field Functions" in help.
3.) Use this technique to make an "Expression Report" which references the field functions that are automatically generated by the Surface Average reports, calculating the pressure drop.
The pressure drop will change with axial distance, as the flow develops. It might be nice to do several seperate pressure drops reports to see how the pressure drop varies with distance from the inlet. If you like, you could reference reports that reference reports to do this!
DaveyBaby is offline   Reply With Quote
Old   April 16, 2014, 03:48
Hi David,
Thank you for your reply. About the boundaries; should i leave the initial pressure value and reference pressure value for the outlet boundary as they are or how should i set these parameters so that the software reads it as it is an outlet boundary opening to atmosphere? Thanks in advance.
Old   April 16, 2014, 05:28
DaveyBaby
Search "Understanding Pressure in STAR-CCM+" for the various pressure definitions, as this will be useful for not only this simulation, but anything else you run! If you set the outlet boundary to "Pressure Outlet", the default setting is 0 Pa "Environmental" pressure, which is what you need for an opening to atmosphere. These questions are all answered in the help documentation, but unfortunately the search function for it is not very practical! I have spent hours going round in loops in the help files!
Old   April 16, 2014, 07:17
Thank you very much Dave you've been really helpful.
Cheers.
DaveyBaby likes this.
Discrepancy between the measurements (pressure drop; VOF) blackemperor FLUENT 2 March 6, 2016 03:40
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 16:29
What's meaning of pressure drop for fluid? qihongming Main CFD Forum 1 April 30, 2009 12:05
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
