June 26, 2014, 06:19 |
cyclone simulation
Hi all
please help me with cyclone simulation. I would like to simulate flow with dust particles, steady flow, pressure difference should be between 1100kPa and 600kPa. Also I cannot see any good result of plot, residuals are so bad. I have 1 injector, and use Lagrangian multiphase any help approciated |
June 26, 2014, 14:27 |
Rep Power: 24 |
Cyclones are hard.
What turbulence model are you using? You should start with standard linear ke and switch to quadratic, then switch to RSM. If you particles are smaller you may want to consider using EMP instead. What is your grid? If you can generate a structured grid, do it. |
June 27, 2014, 00:55 |
venkat
Rep Power: 13 |
Use polyhedral mesh. the convergence will be good.
June 28, 2014, 05:45 |
Hi
Thank you. Seems it's working |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 06:48 |
Huge file sizes when Running VOF simulation | aarratia | FLUENT | 0 | May 8, 2014 12:27 |
cyclone LES simulation prob: ERROR # 004100018 | sakurabogoda | CFX | 15 | November 6, 2012 09:07 |
Cyclone Simulation (simpleFoam) | erncyc | OpenFOAM | 4 | January 28, 2011 09:40 |
About multiphase simulation for cyclone separator | Sushil | Main CFD Forum | 0 | July 7, 2007 05:45 |
