[Sponsors] | |||||
HARIHARAN K
Rep Power: 13 ![]() |
Hi everyone,
Does anybody know how to maintain the wall y+ value within a range..?
Lucky
Rep Power: 68 ![]() ![]() ![]() |
HARIHARAN K
Thank you very much for your reply....I calculated the thickness of near wall prism layer and put prism layer thickness as the turbulent boundary layer thickness.Are these values enough to get the wall Y+ value I need..?..(I didn't get it actually)
#4 | |
Rep Power: 0 ![]() |
From my understanding, y+ is very similar to Reynolds number(y*u_t/ν). The idea of maintaining y+ in a range is to ensure that the first layer grid will be located in certain layer(either viscous sublayer, log-law layer, outer layer, etc), for example, viscous sublayer has a y+ <=5(which is non-dimensional) , you could calculate its real thickness if you know u_t and viscosity, that is usually the thickness you want to know, rather than the overall thickness of the turbulent boundary layer thickness which is much bigger than viscous sublayer thickness. This is because certain turbulence models need to resolve such layers, so you have to make sure you have enough data points(prism layers) in that region... Depending on the layer your turbulence model needs to resolve, you choose the prism layer thickness for it.. Does that make sense? |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Thin Wall Heat Transfer BC for rhoSimpleFoam | swahono | OpenFOAM Running, Solving & CFD | 12 | October 4, 2013 12:49 |
| [Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 07:23 |
| Patches for OpenFOAM 1.7 on MacOS X | gschaider | OpenFOAM Installation | 101 | September 21, 2011 06:37 |
| UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 13:03 |
| Quick Question - Wall Function | D.Tandra | Main CFD Forum | 2 | March 16, 2004 05:29 |
