Temperature condition inside an entire region |
November 19, 2014, 07:59 |
Julien
Rep Power: 11 |
Hello everybody,
I am doing a thermal analysis between two solid regions. I would like to set a temperature condition on the first region (1500°C). In the second region, there is a boundary temperature condition (200°C). I know how to set a temperature condition on a boundary, but I don't know how to set a temperature condition inside a whole region. I just can set an energy source (volumetric heat source, total heat source, specific heat source). Thank you for reading, Twinsen_cfd |
November 20, 2014, 03:15 |
Mark Olesen
Rep Power: 40 |
I don't properly understand your physics. If the entire region really is a constant temperature, you can't actually calculate its temperature at all, since you've just defined this. In this case, that isothermal region can also be removed and replaced with isothermal boundary conditions for any attached regions.
However, I'm guessing that this probably isn't what you meant. Maybe you just want something that is mostly isothermal, in which case you could specify the initial temperature for that region, provide isothermal boundaries and then adjust the material properties (rho, cp, etc) to ensure that this region responses extremely slowly. |
November 20, 2014, 03:36 |
Julien
Rep Power: 11 |
Hello Olesen,
Thank you for your response. In fact I would like that the first region (1500 °C) translates along the second region (with a boundary at 200 °C) and solve the temperature field inside the second region. But I think we can't move a boundary condition (perhaps it is possible?). That is why I created the first region (which can move along the second one). Do you understand what I want to do ? Twinsen_cfd |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
To change temperature in mass flow inlet boundary condition per iteration | ajinkya201991 | FLUENT | 1 | July 11, 2014 11:29 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
Temperature dependant mixed Boundary condition | argonaut | OpenFOAM Pre-Processing | 2 | February 15, 2011 11:02 |
