December 11, 2014, 01:59 |
Problems with Surface Mesh
Raghunandan A Rao
Hi All,
I'm working on computational analysis for a B-series propeller. When using the surface remeshing option, the remeshed surface does not capture the blade tip profile accurately. See the attached picture. Both the surface meshing models - Wrapper and Remesher eat into the blade profile tip. I have varied the base size, used feature curve option, fill holes, zip edges but nothing seems to work. Thanks. |
December 11, 2014, 02:37 |
kris
Rep Power: 12 |
Check to see if the wrapped representation also has this "eating away". If so, then the issue is at the wrapper level. There could be some small leakage, or a gap in the geometry.
December 11, 2014, 17:19 |
Paul Hancock
Rep Power: 17 |
You might consider defining a new surface/boundary that only contains the blade edge and then possibly creating a contact prevention.
Is the geometry simple enough to avoid wrapping? |
mesh, surface remesher, wrapper |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
