z-direction flow problem
Old   December 31, 2014, 21:28
Default z-direction flow problem
Daniel
Daniel4 is on a distinguished road
Hi
im having problem with the flow direction.can anyone help me with it?
im trying to make the flow goes in -z direction.i assigned the inlet and outlet regions.
is it correct if i change the direction in stationary axis in region node (0.0,0.0,-1.0) to make it goes -z direction or is it another way?
here attached the flow when im running the simulation of (0.0,0.0,1.0) for the axis in region.
Daniel4 is offline   Reply With Quote
Old   January 1, 2015, 11:51
hwsv07 is on a distinguished road
did you try instead to specify velocity in your inlet region to be negative instead? did it work?
hwsv07 is offline   Reply With Quote
Old   January 1, 2015, 19:44
Daniel
i did stagnation inlet as for the inlet,not velocity inlet.
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Back flow problem in gas cyclone lakhi FLUENT 0 August 31, 2012 04:27
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
