Tdr Residual does not converge
Old   August 26, 2015, 13:09
Default Tdr Residual does not converge
Alvaro
avidalto is on a distinguished road
My problem, as you can see in the attached plot is that the tdr residual does not converge whereas all the others do.
The simulation is flow in a duct with inlet velocity and outlet pressure boundary conditions. In the middle of the duct there is a metal sheet with holes so that the fluid can only cross to the other side of the sheet through these holes. The fluid inlet velocity is between 1 and 10 m/s. The duct is a 10 cm square duct. The sheer has 50 holes with 2 mm diameter.
Looking at the results everything seems to make sense. There is a great pressure drop in the metal sheet. The fluid accelerates as it passes through the holes etc. However, the Tdr residual is too high.
Can you please help me?
Did anyone have a similar experience?
Thank you very much and please let me know if you need additional information.
Alvaro
avidalto is offline   Reply With Quote
Old   August 27, 2015, 06:04
Lily
daenerys is on a distinguished road
Your solution is not converged at all.
Residuals only dropped one order in magnitude, which is not considered converged. I would not trust these results if I were you.
For the solution to be accurate, residuals need to drop at least 6 orders in magnitude.
What physics models have you used?
I would try playing around with the models a little bit and changing them around.
Also, increasing mesh quality always helps, as well as reducing under relaxation factors.
daenerys is offline   Reply With Quote
Old   August 27, 2015, 12:35
Alvaro
Solution is not converged. However, it does not look as though it is ever going to converge no matter how many time steps I run because the Tdr residual is not getting smaller. I've tried even 9.5 million cells which for a 10x10x80 cm duct with slip condition on the duct walls and 1 m/s inlet velocity is in my opinion a big number.
The models are:
Ideal Gas
K-e Turbulence (Also tried k-w and same thing happened)
Steady
Coupled Flow
And all the default ones
The mesh is tetrahedral with surface remesher and concentrating cells 4 to 1 in the middle part of the duct where the perforated sheet is located. I've tried several meshing models too and obtained the same results.
Thanks!
Old   September 13, 2015, 20:19
me3840 is on a distinguished road
If tdr is having issues generally the problem is with your prism mesh. What does that look like? Can you post images of your mesh? And why are you using the tet mesher? The polymesher or trimmer will give superior results.
me3840 is offline   Reply With Quote
Old   April 4, 2016, 04:35
Default hi
yang
bojueyang is on a distinguished road
The models are:
Ideal Gas
Steady
Coupled Flow
Thanks!
i am facing the same problem , so what do you deal with the problem finally. can you help me, forgive my poor english. thanks a lot!
bojueyang is offline   Reply With Quote
Old   April 4, 2016, 13:03
Yuanming Yu
yym2014 is on a distinguished road
hello,
Try to change the model from couple into segregated. This might work. Thanks.
Yuanming
yym2014 is offline   Reply With Quote
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
