How to apply velocity profile at inlet
Old   June 16, 2016, 16:08
Default How to apply velocity profile at inlet
Edward Kraft
ekraft is on a distinguished road
To make my question as simple as possible, I have gathered experimental data from flow through a square duct. Using an anemometer, I gathered the velocity data at the vertical, horizontal, and diagonal directions. After plotting the data and adding trendlines, I have the velocity functions for the three directions. How do I map these functions to the inlet velocity conditions? Is there a tutorial that I have yet to find that explains this well? I apologize if this is a simple question, I am an undergraduate researcher this summer and I am a beginner with Star. Thank you very much for your time and help!
ekraft is offline   Reply With Quote
Old   June 16, 2016, 16:58
Matt
fluid23 is on a distinguished road
I believe you will want to set physics conditions > velocity specification to 'components' and then physics values > velocity > Table (x,y,z) to define the spatial variation of those components.
Or... you can write a field function that defines the 3 velocity components as a function of xyz and set physics values > velocity > field function...
fluid23 is offline   Reply With Quote
Inlet boundary condition with existed velocity profile wanjia SU2 9 May 10, 2017 05:33
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
inlet velocity profile in Polyflow srinu FLUENT 0 January 16, 2003 20:25
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
