Method I used to monitor wave elevation time history at some certain place in ccm+
Old   October 25, 2013, 07:33
Default Method I used to monitor wave elevation time history at some certain place in ccm+
David
dai549592484 is on a distinguished road
I noticed that some star ccm+ users don't know how to monitor wave elevation time history at some certain place in the wave field. And there was one way to get an approximated data: create a point wave probe attached to the free surface and measure the position of that point, however, the result is not that good.( You can compare this method with the way I used.)
Let's first assume the positive Z axis in upward and positve X axis is along the wave propagating direction. Then you will need to:
1)create a plane section (derived part) normal to y axis, use the whole domain as the input.
2)select the plane section just created as the input and create a plane section normal to x axis, then you will get an intersection of the two plane sections which is a line (will be named plane section 2 if you have not create any other plane section before the 1 one)
3) create a line integral report, select the line as the part and choose volume of fraction>water in the field function.
4)create a monitor and plot for that report.
The result you will get is the wave elevation time history plus the water depth since it integraled the vof water along the line from the start point of the line to the end. So you can either create an expression report, call the line integral report and minus water depth or simply post prossess it via excel.
P.S: don't use the line probe build in star ccm+ to do so since the line probe built in has limitaion of integral I guess. (I've failed in doing so)
dai549592484 is offline   Reply With Quote
Old   November 3, 2015, 23:22
Default Thanks David
freeday's Avatar
freeday
freeday is on a distinguished road
I have tried your way to make a report of wave elevation. Previously, I use field function of Centroid [Z] of cross section between iso-surface of volume fraction and plane normal to x. But, my graph is look steps.
Thank a lot.
Fred
freeday is offline   Reply With Quote
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 22:05
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
