December 23, 2015, 07:03 |
unsteady velocity field as inlet condition
Sergey
Rep Power: 10 |
Hi everyone,
I have two questions. I calculated unsteady velocity field into the pipe after the rotating part. I want to export the velocity field and then use this data as input conditions in the new simulation. How do I export data containing the velocity field depending on the time? How to use the data then (as inlet)? Thanks |
December 23, 2015, 23:51 |
#2 | |
Lane Carasik
Rep Power: 14 |
Some specific keywords that might help are ramping boundary conditions, user defined table, or import table. |
December 24, 2015, 03:28 |
Sergey
Rep Power: 10 |
For time-dependent inlet boundary i need to imort table(xyz, time), but i see no way to export this table(xyz, time) from my first sim, there is only an option to export table(xyz).
December 24, 2015, 03:33 |
#4 | |
Lane Carasik
Rep Power: 14 |
Under the tools drop down menu -> right click tables -> create internal xyz or desired table type -> export desired date from the part or surface. |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
Velocity Inlet Boundary condition in LES | babakflame | OpenFOAM Running, Solving & CFD | 0 | April 21, 2014 10:40 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Inlet velocity boundary condition in Polyflow | ZHANG Xian-Ming | Main CFD Forum | 0 | October 18, 2006 21:06 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
