November 9, 2020, 17:27 |
Modelling blood flow in pipe
jas
Rep Power: 5 |
So ive started a mini project by creating a pipe with spheres inside of it to see how these spheres affect blood flow through the pipe. The pipe is ~9mm in diameter and the spheres are 0.5mm in diameter. Ive set up everything from creating physics with properties of blood flow.
My only issue or concern is why is it taking so long to create a volume mesh? My base size is 0.2mm and everything else is default. I have used polyhedral mesher, prism layer mesher and surface remesher. It is currently generating subsurfaces at the 33000th iteration now. Is something wrong? If i increase the base size to 1m, the pipe does not even generate, only the spheres do but even then, the spheres are pyramid shaped. Any suggestions on what to do? |
November 10, 2020, 07:54 |
#2 | |
Devansh
Rep Power: 6 |
Else there shouldn't be any problem for such a simple geometries like pipe n small sphere.... |
November 27, 2020, 21:50 |
#3 | |
Aleksandr
Rep Power: 5 |
First rule: at least 4 cells per minimum body size. Second rule: go to the region and adjust the mesh for the particle there. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
blood flow simulation start-up hints please | olumide olododo | Main CFD Forum | 4 | May 31, 2004 11:33 |
