Virtual Disk Model - Propeller Performance Curve
Old   April 20, 2016, 16:42
Default Virtual Disk Model - Propeller Performance Curve
hlf13 is on a distinguished road
I'm trying out the virtual disk model (Body Force method) in Star CCM+ for a simulation. I'm wondering about the performance curve of the propeller that have to be set. Do I have to find the performance curve for every RPM that I want to test, or do I just have to find the performance curve for one specific RPM, and then use this in the virtual disk on every RPM I try out?
hlf13 is offline   Reply With Quote
Old   April 22, 2016, 11:37
Matt
fluid23 is on a distinguished road
Yes, you need this. If you don't know the propeller performance curve already, then the Virtual Disk BF method is not the right tool for the job. What exactly are you trying to do here?
fluid23 is offline   Reply With Quote
Old   April 23, 2016, 07:14
I have the performance curve now, and this is, as far as I can see, the same for every RPM.
Another question; do you know what the settings of the time-step will be with Virtual Disk? The same as for the propeller (in my case 1 deg per time-step)? Or can the time-step be higher when using virtual disk?
Applying BEMT thrust distribution to actuator disk model Cheffrey CFX 1 June 25, 2014 22:41
Virtual inheritance problem while adding public member function to LES SGS Model konneym OpenFOAM Programming & Development 4 November 4, 2013 11:37
Pump characteristic / performance curve husker STAR-CCM+ 4 February 20, 2012 03:46
plotting a performance curve of centrifugal Fan altano CFX 2 October 18, 2008 07:12
Propeller model (CFX-5.7.1) Jesper CFX 6 April 18, 2005 19:31
