Heat Transfer - how to use a surface as custom control? |
October 31, 2016, 08:13 |
Eike
Rep Power: 14 |
I am modeling heat transfer and want to get a surface for a local heat transfer coefficient.
I set a threshold at the interface between fluid and solid to capture the area of interest. Then I exported this surface as *.stl and importet it to another sim with the same cooled part but without the fluid region. I want to model only the solid as it is way faster and I am not interested in the fluid at this time. Is there any way to use the imported surface as a heat flux or heat transfer coefficient? |
November 1, 2016, 10:29 |
Kevin
Rep Power: 13 |
From your source sim file, you can use that threshold to export a table of data (Specified Y+ HTC and temperature are usually preferred). Then, in the solid-only file you can create a Tabular Data Mapper to map data from the table to your target surface. Within the data mapper, expand Target Specifications > Surface > Proximity constraint. Enable this and set appropriately. Once it's enabled, it gives the option to set "alternate values" for cells that do not get mapped. I would recommend an HTC of 0 and temperature of 300K. Once this is defined, map it, then use the MappedSpecifiedY+HTC and Tref as the HTC and Tref boundary condition for the surface you are mapping it to.
This is the most straightforward way that I see to do what you are asking. Just keep in mind that if your solid solution changes temperature (transient or different boundary conditions), the fluid temperature would also change, which may (or may not) have a significant effect on heat transfer. By decoupling the two, you could miss this effect. |
November 8, 2016, 04:42 |
Eike
Rep Power: 14 |
Thanks a lot! Your answer was VERY helpful :-)
November 24, 2016, 11:42 |
Chaotic Water
Rep Power: 17 |
If i got you right - you want to make a computation of heat transfer in solid (which is slow) and not waste time on solving fluid dynamics part after fluid flow has reached it's steady state.
In this case - you can select "Freeze Solver" for fluid (Pressure-Velocity) in Solver controls and thus only energy equations will be solved which is much faster. |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch | icaro | FLUENT | 0 | November 24, 2009 07:01 |
surface to surface radiation heat transfer? | suresh | Siemens | 1 | July 7, 2006 06:54 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
