Question about anisotropic thermal conductivity
Old   June 30, 2016, 06:43
Question Question about anisotropic thermal conductivity
Alex Szwaykowski
Szweyk is on a distinguished road
I just started using STAR-CCM+ 9.02 as part of an internship and I've run into a problem that seems a bit over my head. I need to model the anisotropic thermal conductivity of a solid object and the issue I'm running into is that the thermal conductivity needs to be anisotropic and temperature dependent.
I was able to model temperature dependent thermal conductivity as a 'Polynomial in (T)' for isotropic thermal conductivity, but when I switch to anisotropic thermal conductivity (Continua> Physics> Models> Solid> Al> Material Properties> Thermal Conductivity), that option is no longer available. Instead, I have to go down through "Regions> Body> Physics Values> Anisotropic Thermal Conductivity> Principal Tensor" in order to describe the thermal conductivity in the XX, YY, and ZZ directions. Unfortunately, my only options for describing thermal conductivity values in these cases are to use a constant, a table, a field function, or a user code. It's a little strange that the option for 'Polynomial in T' exists for Thermal Conductivity, but not for Anisotropic Thermal Conductivity. Is there a reason for this, or am I just misunderstanding something?
Can anyone help me figure this out? I'm trying to learn how to use a field function or user code to do this and as someone who has never coded in C, C++, or Fortran, it's a bit overwhelming for me.
Thanks!
Szweyk is offline   Reply With Quote
Old   June 30, 2016, 07:34
taillanm is on a distinguished road
You could use the "polynomial in T" and put it in form of a field function as you suggested; you should have the coefficients and exponants of your polynomial and the field function would have to be defined for the interval of temperatures you consider:
[T1 - T2] : a*T^b +c*T^d etc..
taillanm is offline   Reply With Quote
Old   June 30, 2016, 08:26
Alex Szwaykowski
Thanks for the response,
Just to clarify, this would mean that I would define a unique field function for each direction (XX, YY, and ZZ) which would be defined by a polynomial involving the primitive field function "Temperature"; is this correct?
anisotropic, field fucntion, user code
thermal conductivity --> anisotropic material val46 OpenFOAM 17 February 9, 2023 13:03
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 13:32
How to define Brownian thermal Conductivity in Star CCM+ ? iSaeed STAR-CCM+ 0 December 29, 2014 06:12
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Anisotropic thermal conductivity Helger Dooley CFX 2 September 1, 2005 08:52
