Trimmer Vs Polyhedral - Drastic fall in data for poly mesh
Old   October 6, 2017, 11:27
Exclamation Trimmer Vs Polyhedral - Drastic fall in data for poly mesh
Bharatt's Avatar
Bharat
Bharatt is on a distinguished road
i am comparing results for an HVAC system with different meshes(timmer and poly).with trimmer mesh the results are quite acceptable. on the otherside, i am not changing anything, like mesh settings, boundary conditions etc.
coming to the results i am seeing a drastic fall in the data (avg. velocities, avg. pressure, mass flow rate etc.) collected for poly mesh.
can anyone share ideologies what can possibly go wrong?
chapter 3:
-crossing the threshold-
Bharatt is offline   Reply With Quote
Old   October 12, 2017, 06:06
Guillaume Jolly
trampoCFD is on a distinguished road
Send a message via Skype™ to trampoCFD
Hi Bharatt, you probably have a strong gradient (in velocity?) and your polyhedral mesh is not capturing it?
What part of the HVAC system are you modelling?
Best regards,
Guillaume
TrampoCFD.com
trampoCFD is offline   Reply With Quote
Old   December 5, 2017, 06:45
Default poly is good
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
If mesh is done right poly should give very good results. I prefer using trimmer only when mesh count is an issue. So problem may be in mesh itself.
ashokac7 is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Interpolating Data onto a Uniform Mesh wadeellis STAR-CCM+ 3 November 2, 2015 16:58
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
