Area averages of circles / ring
Old   September 14, 2016, 06:36
Default Area averages of circles / ring
acalado's Avatar
André
acalado is on a distinguished road
Hey guys,
I was wondering if there is any way in Star-CCM+ to create surface averages of a specific circle of radius R1, or of a ring with radii R1 and R2 ?
I.e. imagine I have a tube of 25mm radius, but would only like an average of a circle with 10mm radius, is this possible using a derived part or some other way ?
Thanks in advance for any response!
Cheerio
Sapere aude!
acalado is offline   Reply With Quote
Old   September 15, 2016, 13:30
Gajendra Gulgulia
ggulgulia is on a distinguished road
I am sorry I did not get your question. Can you tell us what exactly is the physical phenomema that you want to simulate/ capture/ execute.
In the case of post-processing we can capture the results by creating probe poins, filed functions, reports, table values etc. or incorporating the desired boundary, regions feature during the cfd modelling for us to capture the results easily.
Regards
ggulgulia is offline   Reply With Quote
Old   September 16, 2016, 02:15
mi_cfd is on a distinguished road
You can create any surfaces you want in the 3D-CAD modeler, for example by creating a sketch then extruding it as a sheet body. Then you can move these bodies to the Geometry Parts node, and create an Arbitrary Plane Section using surface(s) from the Parts.
Once you have the Arbitrary Plane Section, you can create a surface average/integral report of any field function on it.
For detailed instructions on this, search the user guide for Arbitrary Plane Section.
Cheers!
mi_cfd is offline   Reply With Quote
Old   September 18, 2016, 13:53
acalado's Avatar
André
Originally Posted by mi_cfd View Post
Cheers!
So the easiest way to do a surface average based on a ring should be to create one in the CAD and then use it?
Sapere aude!
Problem with reference area alfaben STAR-CCM+ 3 April 21, 2020 09:46
[OpenFOAM] Problem with cell area calculation in a slice daniel87 ParaView 5 October 24, 2015 16:18
Non overlap area fractions saisanthoshm88 CFX 11 September 17, 2015 18:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
