January 18, 2017, 09:14 |
Large mesh
André
Rep Power: 10 |
Hey,
I am trying to build a quite ambitious mesh (over 100M cells), but am unsure of the best wya to do this. I've tried using 2 machines, with 1 process each to build it but I get a memory exception error. Is anyone aware of problems while meshing in parallel devices? Or is it safer to just use 1 computer, 1 core? Thanks in advance!
Sapere aude! |
January 19, 2017, 15:22 |
Rep Power: 24 |
I have made meshes in excess of 800M easy, but you have to use several machines.
What type of mesh are you making? I would not recommend making a polymesh that big, but the trimmer is easy. |
January 20, 2017, 08:56 |
André
Rep Power: 10 |
Right, I was using poly since the flow is in porous medium and is not really aligned with a specific direction. From my experience poly meshes had better chances to converge, but I'll try a trimmed one now.
Sapere aude! |
mesh quality checking for large internal flow (yStar) | vaina74 | OpenFOAM Post-Processing | 0 | November 21, 2014 07:49 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
