Time step unsteady nozzle flow, impingement on plate |
February 24, 2017, 05:56 |
Rep Power: 10 |
Hello everyone,
I am modeling a nozzle flow impinging on a plate (about 1m away from the nozzle exit), and I would like to monitor the pressure on my plate. (Pressure in the chamber: 90bar, Mach at exit around 3) Since I'm new to unsteady simulations I'ld like to know if anyone has a good rule of thumb to select the time step + number of inner iterations for such a case. |
February 24, 2017, 10:41 |
#2 | |
Lane Carasik
Rep Power: 14 |
I highly recommend you look into what the CFL (Courant number) number is. This is a basic quantity used for stability of numerical methods and is not meant to be a randomly selected number. Also, I do not believe Star-CCM+ can handle mach flows. Edit: Apparently Star-CCM+ Can handle higher (supersonic and transitional flows). My apologies. Last edited by lcarasik; February 24, 2017 at 12:29. |
February 24, 2017, 10:51 |
Rep Power: 10 |
Hi, thanks for the reply
what i meant with mach at exit is just an indication, and not some value I would use for some boundary condition (i use a stagnation inlet) |
March 6, 2017, 07:28 |
Rep Power: 10 |
I know that it takes about 10ms to reach my total pressure in the chamber, I will linearly go from 0 to 90bar in 10ms. Is a time step smaller than 1ms necessary? Cheers |
March 7, 2017, 09:07 |
Rep Power: 24 |
STAR-CCM+ is perfectly capable of simulating high-mach flows.
Why are you ramping up the inlet pressure? Are you interested in the formation of the jet or only what the jet does after it's formed? As Icarasik said you need to look into the CFL number, it will inform you how big you should make your timestep. However you don't have to make it exactly 1, since this is implicit. |
nozzle flow, time step |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
