Split Flow Domain
Old   March 4, 2017, 18:51
Default Split Flow Domain
Jaydeep Kashikar
Jaydeep Kashikar is on a distinguished road
I wanted to know is it possible to create a split flow domain in STAR CCM. What i mean by it is outlet conditions of one flow domain being used as inlet conditions for another.
I want to analyse a vehicle in the wake of another. Since putting in 2 vehicles in the same domain may require a lot of computing capacity and time. So I wanted know if this is possible and if so how does one go about doing it.
Jaydeep Kashikar is offline   Reply With Quote
Old   March 5, 2017, 04:35
Ping
ping is on a distinguished road
sounds like you want to run two separate cases with the second having the outlet flow conditions from the first as inlet to the second.
if this is what you want then it is easy using a table to store the outlet boundary state of the v components and pressure and tke and tdiss then save this as a csv file and import into the second case and apply as the inlet conditions
ping is offline   Reply With Quote
Old   March 5, 2017, 07:39
Jaydeep Kashikar
Thanks. yes that's exactly waht i want. i will give it a try....dont know how exactly to do it though
Old   March 5, 2017, 13:17
Lane Carasik
lcarasik is on a distinguished road
Have you tried looking at the manual or tutorials that use tables?
lcarasik is offline   Reply With Quote
star ccm+, turbulence analysis, wake modeling
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 00:42
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
[blockMesh] Flow domain by BLOCKMESH for plasma induced flow simulation mukut OpenFOAM Meshing & Mesh Conversion 0 June 2, 2014 06:19
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
