DEM modeling - The particles (balls) are outside the wall |
August 2, 2018, 19:41 |
D Huang
Rep Power: 7 |
I created a DEM modeling - a screw axel rotates in vessel. The screw and vessel axels are offline. So the balls are expected to flow only on one side which has sufficient space.
How ever, I visualized the balls go to the another side which is too small to contain the balls. In Sence, part of the balls are outside the vessel wall. Although I have defined the vessel wall boundary as a "wall". Please see the following pictures. If the professional here have the similar situations, could you let me know what is the problem, do we have solutions? Thanks, |
Permeable plate modeling / transpiration cooling / porous wall | mottle | FLUENT | 6 | January 30, 2016 13:47 |
[mesh manipulation] mergeMeshes problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 3 | July 29, 2015 04:15 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Particles do not hit the wall | CedricVH | OpenFOAM | 0 | April 15, 2010 08:21 |
turbulent modeling with wall functon(or modeling) | yoo seon oh | Main CFD Forum | 5 | July 4, 2007 14:06 |
