March 31, 2017, 19:36 |
Centrifugal Pump No Initial Conditions Known
Shawn
Hey Everyone!
I just started using Star-CCM+ and I am trying to use it to predict the pressure and mass flow using only 3D data and impeller rotation speeds. Is this possible? How would I go about setting up the model? Setting the boundary conditions is really throwing me for a loop. The solution I thought of was a mass flow inlet and a pressure outlet and set them far enough away that I can measure the flow and pressure before the 0 conditions influence the flow too much. Not sure how that would turn out though. Any help or directions to instructions would be greatly appreciated! |
June 4, 2017, 15:08 |
cfd Engineer
Rep Power: 11 |
Normally for MRF based one total pressure inlet and static pressure outlet is enough .. because based on rotation speed will give massflux data...and increase speed step by step ...so nope in initial conditions
Sent from my Lenovo A7020a48 using CFD Online Forum mobile app |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 08:07 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
