Table xyz,t
Old   May 23, 2017, 17:39
Default Table xyz,t
Mesut
mesut is on a distinguished road
I'm working on a compressible flow problem.
Firstly, i'm very new at CFD.
I should apply time dependent velocity in inlet. I searched some topics about this and i see that i should use table xyz,t. Is this correct or not? If it's correct, i created a table for just trying this method but i have some errors when i start to run. "non-existent column "null""
where is my fault?
I'm sorry if this question is nonsense
I hope you can help me.
mesut is offline   Reply With Quote
Old   May 23, 2017, 19:14
me3840 is on a distinguished road
If you have that error then your boundary condition is missing a specification. You set the BC to be the table, but you didn't tell STAR-CCM+ which column is what data. Go back and look at your BC
me3840 is offline   Reply With Quote
Old   May 23, 2017, 19:33
Mesut
Thank you for your answer.
I applied velocity inlet and under the velocity properties, i choosed table xyz,time. Under the table option, i chose my table but i couldn't set table: X-data , Y-data and Z-data. Because none available is written there.
Probably this problem isn't hard to solve but i don't know this program well. Maybe i did some mistakes in other parts. Though i checked my table, i didn't see any problem but i'm confused. I also could not find this method in detail in the user guide.
Old   May 29, 2017, 08:40
taillanm is on a distinguished road
If you imported the csv data from somewhere, maybe the format of the table is not correct
taillanm is offline   Reply With Quote
Old   May 29, 2017, 10:50
Mesut
Thank you,
I think you are right,probably i did some mistakes about format of the table.
Old   April 18, 2019, 07:21
Mohamed
gaddora165 is on a distinguished road
what is the correct format ?
I have the same error but yet could resolve this error.
please share your experience.
gaddora165 is offline   Reply With Quote
Modifying CFD-Post macro to output a time-varying expression at every timestep lynnathere CFX 0 December 28, 2015 15:19
Run time Selection Mechanism - Some help required to understand jaswi OpenFOAM Programming & Development 3 October 29, 2015 13:42
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 04:40
Installing OpenFoam on windows 7-64 Dadou OpenFOAM Installation 10 February 11, 2014 16:20
Table Manipulation furkan Siemens 0 April 4, 2006 10:23
