June 9, 2017, 07:41 |
turbulent prandtl number
mike
Rep Power: 14 |
Dear All
I am studying hypersonic flow over a sphere using SST turbulence model. using constant turbulent prandtl number as 0.9, wrong (high) heat flux is computed at stagnation point. It seems that variable turbulent prandtl number is necessary in order to compute turbulent conductivity. Turbulent conductivity is computed high at stagnation results in high heat flux. Thanks for any idea |
June 9, 2017, 14:13 |
#2 | |
Lane Carasik
Rep Power: 14 |
June 11, 2017, 04:27 |
mike
Rep Power: 14 |
I want to know if it is necessary to use a variable turbulent prandtl number for hypersonic flows in order to compute wall heat flux well. If so, what's that variable turbulent prandtl function? |
June 11, 2017, 23:17 |
#4 | |
Lucky
Rep Power: 66 |
That variable turbulent Prandtl function is not trivial, coming up with one is the same level of difficulty as coming up with a turbulence model. It is a turbulence model, but for the energy equation instead of the momentum equation. You would have to really read some papers and find some literature on this topic. But nowadays, few people are working on turbulence models and even fewer are working on energy models. |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
Turbulent Prandtl number | Ravenn | FLUENT | 14 | June 20, 2017 11:13 |
Turbulent Prandtl number | marsnova | FLUENT | 1 | May 3, 2013 10:01 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
