June 30, 2017, 05:39 |
Run job when license free
Rep Power: 10 |
I would like to write a script that checks the licenses used for StarCCM and as soon as one frees up, open a .sim file and launch a macro for example. At the moment I only have an alias to check the licenses in use. On the steve portal they mention some environment variable called starwait but didn't put an example of how to use it. Does someone have more experience with this? Thanks, Max Last edited by taillanm; June 30, 2017 at 08:09. |
September 25, 2020, 05:35 |
MK
You can simply set environment variable. For example in bash:
export STARWAIT=1 It ensures that if you run starCCM application and there is no license, then the app waits until one is free. So you do not need to write any script. Status of a request on a lic server side is QUEUED when waiting for a free license. |
October 13, 2020, 10:08 |
#3 | |
Rep Power: 10 |
Thanks, works perfectly |
licenses, scripting |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 41 | August 23, 2023 02:48 |
chtMultiRegionSimpleFoam: crash on parallel run | student666 | OpenFOAM Running, Solving & CFD | 3 | April 20, 2017 11:05 |
Radial jet with free surface using FIDAP | Dr. Ahmed Hassaneen | Main CFD Forum | 0 | October 28, 1999 13:20 |
cfd job | Dr. Don I anyanwu | Main CFD Forum | 20 | May 17, 1999 15:13 |
