September 5, 2017, 03:25 |
Area or Volume on a plane
Paresh
Rep Power: 8 |
For my calculation on a section plane, I am trying to extract the area of each cell but I am getting double variable as the error. So to verify and have a look at the values. I create XYZ internal table and I select my plane as the part and for the function, I select all the areas( magnitude, Cartesian-i,j,k, Cylindrical.i,j,k) to have an idea. But on extracting, it is observed that everything has the exact same value. Also, further I tried to plot volume on the same plane. And here I could extract volume for each cell. Well, now I do not know why I do not get an area but volume is possible? Any clue on why this is so? Thanks in advance. <IMG https://ibb.co/hCvfeF IMG> <IMG https://ibb.co/dUE1mv IMG> |
September 11, 2017, 07:26 |
Ping
Rep Power: 20 |
works fine for me getting area magnitude of the section cut area thru each cell and i can have a scalar scene confirming the area values are sensible and then extract in a table so your problem could be the version used since i seem to remember something about better post processing of section planes in the last few versions and i am using 12.04
[blockMesh] blockMesh error - Negative Volume Block | adoledin | OpenFOAM Meshing & Mesh Conversion | 2 | June 22, 2016 10:44 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
Non overlap area fractions | saisanthoshm88 | CFX | 11 | September 17, 2015 18:42 |
I cant view the volume and surface area in geometry | daran555 | FLUENT | 0 | June 25, 2014 11:40 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
