October 26, 2017, 19:18 |
Surface Faces from imported geometry
Miguel
Rep Power: 8 |
Hi everyone!
I am trying to run a simulation of cooler with forced convection, like the one of the tutorial. However I have a problem when I import the geometry. The CAD is done in SW, and it is basically a solid box with an air entry and out, and inside it is an cooler and it's heat source. When I import the x_t file, star creates three parts as expected, however each only have one surface face, which complicates thing creating the regions and contact interfaces. Do Someone knows how to get an imported part as the one of the tutorial. Thanks a lot MP |
October 28, 2017, 01:22 |
Ping
Rep Power: 20 |
try doing a basic tutorial on geometry and meshing - there are several ways to split surfaces.
November 1, 2017, 20:55 |
Miguel
Rep Power: 8 |
Thanks for the reply. I know how to do it, my point was if there is any option of importing the surface to geometry already separated.
November 1, 2017, 21:56 |
Ping
Rep Power: 20 |
in all the supported cad formats that can be imported there is a way to rename or identify faces in the original cad before export and those surfaces and names come into star but i dont know the property to change in solidworks but a bit of experimenting should find it
November 1, 2017, 22:49 |
Miguel
Rep Power: 8 |
OK, I will check with the CAD options. Thanks a lot for the replies.
imported geometry, surface faces |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[snappyHexMesh] snapEdge - failure | Tobi | OpenFOAM Meshing & Mesh Conversion | 33 | March 18, 2014 03:58 |
[snappyHexMesh] Open surface - geometry imported from solidworks | augusto.s.b | OpenFOAM Meshing & Mesh Conversion | 1 | April 24, 2013 23:17 |
