(Java) Get coordinates of a point on a boundary? Use a vector as the z-axi?
Old   December 12, 2017, 04:37
Question (Java) Get coordinates of a point on a boundary? Use a vector as the z-axi?
tisa is on a distinguished road
Hello together,
is there any way to get coordinates of a point of a boundary via macro? I'm currently using the centroid function (surface avg report) to get the midpoint of a boundary. I'm looking for a way to get another point, to create a vector.
My goal is to create local coordinate systems in the midpoint of boundaries. I want the z-axis to be the normal vector of those boundaries.
My current idea is to create three vectors:
  • Vector 1 (x-axis): midpoint + another point on the surface
  • Vector 2 (z-axis): normal vector via surf avg report + normal function
  • Vector 3 (y-axis): Cross product of vector 1&2
I didn't find any way to use the normal vector directly as the z-axis (this would be the easiest way).
So anyone an idea how to get another point on a boundary beside the midpoint or knows how to create a local cs and use the normal vector of this boundary directly as the z-axis?
Thanks in advance.
tisa is offline   Reply With Quote
Old   December 12, 2017, 07:37
I found a workaround for my problem with the local cs:
Create a normal vector of the boundary -> create a local cs with the normal vector as the x-axis -> rotate the local cs around its y-axis for 90 deg.
boundary, java, local coordinate system
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
