May 30, 2018, 12:25 |
Invisible body
I am quite new to the program and attempting the backwards facing step tutorial. after making the step geometry itself , I made a sketch and extrusion(volume) for mesh refinement however i dont see this separately in the body tree. When I click on the step geometry body name, both the backward step and the new volume are highlighted.
I tried naming the step beforehand and then making the part but the same problem occurs. I also tried changing the extrusion method from up to face to blind. I dont see what else I can do. How do I make these 2 into separate bodies so I use this volume further down the line. Assistance with this would be humbly appreciated. stepbody.jpg sketch2 outlined in blue.jpg extruded sketch2.PNG notshowingup.jpg |
May 30, 2018, 15:30 |
Matt
I don't use 3D cad a lot, but I believe your extrusions merge by default. Edit your second extrusion and change the interaction from merge to imprint... I think.
3-d cad models, bodies |
6dof model - floating body | flinde | FLUENT | 13 | March 6, 2021 14:32 |
Propulsion of solid body in two phases | Nautiker87 | OpenFOAM Pre-Processing | 0 | September 29, 2017 06:45 |
Two Way FSI of Highly Flexible Body | Sunny Chitti | Structural Mechanics | 0 | June 27, 2017 14:22 |
[snappyHexMesh] dynamic mesh: rotating body with increasing/decreasing distance to fixed body | mo_na | OpenFOAM Meshing & Mesh Conversion | 3 | July 26, 2016 04:51 |
[Need some advise] Am I doing right?? Simulating a rotational mixer | setasena | STAR-CCM+ | 4 | March 10, 2013 10:32 |
