July 13, 2018, 02:14 |
MRF on single Boundary
sthish
Rep Power: 13 |
How to model/use MRF approach if i have very less clearance between Rotating region and wall, Ex: Impeller and Casing?
Clearance value is 0.5 mm |
July 18, 2018, 02:29 |
Rep Power: 24 |
Just include the casing in the MRF region and set the velocity on the casing such that it's stationary.
July 19, 2018, 05:21 |
sthish
Rep Power: 13 |
I did not understand
set the velocity on the casing such that it's stationary could you Please elaborate I am working in StarCCM+ |
July 19, 2018, 09:31 |
Rep Power: 24 |
If you put the impeller and casing in an MRF they act as if they're rotating with the MRF. All you want to do is change the boundary condition on the casing and set the velocity so that it's stationary with respect to the MRF.
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
