August 9, 2018, 09:29 |
mesh construction for heat exchangers
Nils
Rep Power: 10 |
I'm working on CFD-Simulation of micro scale heat exchangers in cyclic operation. Which means, it is actually a regenerator which stores the process energy and later release it again. So what is my question about? It is the first time I regard the energy equation in a CFD-Simulation. In other projects before, the thermal influence was nigligible. For my mesh construction: Do I have to regard something special, like extra fine mesh at the boundaries to solve the thermal sublayer? I mean I allready try to have fine meshes at the boundaries for my Y+ values, as most of the cases I study are under turbulent conditions. I appreciate your knowledge and help. Best regards Nils |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 19:34 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
