October 17, 2018, 12:48 |
Find Node Numbers
Yogesh Nalam
Rep Power: 13 |
I want to export NODE NUMBERS of the boundary cells with HTC values from Star CCM+ (to be imported in Abaqus at a later process.) Is there a way to export node numbers ? Last edited by nalamyogesh; October 19, 2018 at 09:13. |
October 17, 2018, 16:39 |
Rep Power: 24 |
You can export scalars to NASTRAN files which you can import into Abaqus. Check out the user guide, it's in there.
October 19, 2018, 03:28 |
Yogesh Nalam
Rep Power: 13 |
Hello me3840,
Thank You for the response. But I want the node numbers of the surface to be readable in any normal text editor (may be in a .csv format) as it possible from proSTAR (Star CD). |
October 19, 2018, 03:31 |
Rep Power: 24 |
NASTRAN files are ascii, they should be plenty readable in a text editor.
October 19, 2018, 04:55 |
Yogesh Nalam
Rep Power: 13 |
Thank You so much. I could open it as an ASCII. But it is giving me the node coordinates. I am looking for Node Numbering aswell.
November 5, 2018, 17:16 |
PK
Rep Power: 15 |
Try exporting in Bounday Shell file format. This will give you three files, .cel, .vrt, and .daten. The cells wills be triangles (poly and trim faces will be decomposed) and the data will be in the .daten file.
export data, node id, node number, starccm+ |
128 core cluster E5-26xx V4 processor choice for Ansys FLUENT | F1aerofan | Hardware | 30 | January 19, 2018 03:53 |
SAP cluster resource/services not coming online on cluster node 2 | Nthar1@yahoo.com | Hardware | 0 | May 9, 2017 05:55 |
Node number CFX | Jiricbeng | CFX | 2 | January 5, 2016 07:40 |
[foam-extend.org] Installing foam-extend 3.1 on Ubuntu 14.04 | stephie | OpenFOAM Installation | 16 | April 23, 2015 16:18 |
How to find & view location of a node in CFX? | Bill | CFX | 2 | December 6, 2005 13:18 |
