StarCCM+v12.04 on Linux, unable to open Scene or Plot
Old   October 31, 2018, 05:31
Default StarCCM+v12.04 on Linux, unable to open Scene or Plot
Dennis1984 is on a distinguished road
I installed StarCCM+v12.04 on my Notebook. The installation package is STAR_CCM+12.02.011_01_linux-x86_64-r8.tar.gz.
When I try to open a Scene or a Plot on a loaded .sim file
I receive the following message at the terminal window (where I also launch StarCCM+v12.04):
libGL error: unable to load driver: i965_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: i965
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
The mentioned driver are on my system located in:
dennis@DennisNotebook:/usr/lib/x86_64-linux-gnu/dri$ ls
i915_dri.so nouveau_dri.so r600_dri.so virtio_gpu_dri.so
i965_dri.so nouveau_vieux_dri.so radeon_dri.so vmwgfx_dri.so
i965_drv_video.so r200_dri.so radeonsi_dri.so
kms_swrast_dri.so r300_dri.so swrast_dri.so
Does anyone know why StarCCM+ can't load the driver?
I hope, I made myself clear and I'm looking forward to your suggestions.
system specs:
System: Host: DennisNotebook Kernel: 4.15.0-20-generic x86_64 bits: 64 gcc: 7.3.0 Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1) dm: lightdm Distro: Linux Mint 19 Tara Machine: Device: un-determined System: LENOVO product: 20JH002KGE v: ThinkPad Yoga 370 serial: N/A Mobo: LENOVO model: 20JH002KGE v: SDK0J40697 WIN serial: N/A UEFI [Legacy]: LENOVO v: R0HET27W (1.07 ) date: 01/25/2017 Chassis: type: 31 serial: N/A Battery BAT0: charge: 40.4 Wh 92.9% condition: 43.5/51.0 Wh (85%) volts: 15.7/15.3 model: SMP 01AV433 serial: <filter>status: Discharging CPU: Dual core Intel Core i5-7200U (-MT-MCP-) arch: Kaby Lake rev.9 cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10848 clock speeds: min/max: 400/3100 MHz 1: 3099 MHz 2: 3100 MHz 3: 3100 MHz 4: 3100 MHz Graphics: Card: Intel HD Graphics 620 bus-ID: 00:02.0 chip-ID: 8086:5916 Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting (unloaded: fbdev,vesa) Resolution: 1920x1080@60.00hz OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) version: 4.5 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yes
Dennis1984 is offline   Reply With Quote
Old   October 31, 2018, 12:46
me3840 is on a distinguished road
If you run the command glxinfo, what does the system report?
To me it looks like your system has the correct software
Does your system have dual intel/nvidia graphics? Why is the nouveau driver installed?
me3840 is offline   Reply With Quote
Old   November 1, 2018, 04:06
glxinfo gives me a lot of stats, but I can't make much out of it.
I atttached the whole output.
Regarding your second question: to be honest I have no clue why the nouveau driver is installed and I only found Intel:
dennis@DennisNotebook:~$ lspci | grep -i --color 'vga\|3d\|2d'
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
Old   November 1, 2018, 13:29
The problem is here:
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
So somehow your laptop is not using a hardware graphics driver, it's still using software rendering (it's interesting it still states Direct Rendering: yes, that's a bit confusing).
Have you tried updating your graphics driver? Try to get the proprietary driver from Intel. Otherwise the integrated chipset may not be sufficient to do anything 3D.
Old   November 5, 2018, 06:12
I updated the graphic driver but the same error occurs.
like mentioned before, it seems everything needed is there but the program has no access or couldn't find the driver.
In other programs like Mat Lab or Google Earth 3d visualisation works perfectly well.
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
turn off auto open scene JohnAB STAR-CCM+ 4 March 28, 2014 01:49
