Waiting for client to catch up
Like Tree1Likes
  • 1 Post By me3840
Old   November 13, 2018, 19:27
Unhappy Waiting for client to catch up
Rinia
Rinia is on a distinguished road
The output window shows "Waiting for client to catch up" and when I click "stop", it shows "waiting for current iteration to complete".Now I cannot stop and save the simulation.
Anyone encounter this trouble before?By the way,I use the version 11.02
Thanks a lot for your help.
Rinia is offline   Reply With Quote
Old   November 13, 2018, 21:32
me3840 is on a distinguished road
The message "waiting for client to catch up" occurs when the queue for completing image rendering has grown long.
In that instance the server process will stop iterating until the client can finish all of its work.
This happens often when you are either (a) saving too many images too fast or (b) saving an image too complex for software rendering.
The obvious solutions are to (a) stop saving so many images or save them more infrequently and (b) use hardware rendering.
Zalan likes this.
me3840 is offline   Reply With Quote
Old   November 13, 2018, 21:44
Rinia
Thanks a lot for your answer.
This issue troubles me for a long time.I‘ll try your method.
Old   November 16, 2018, 11:07
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
Star-ccm was built from the start to have a client-server architecture and that influences some of its behavior. For example when you (on the client) presses the stop button, you send a message to the server to stop iterating. But the server doesn't respond this command until it finishes doing whatever it is currently doing and executes the stop task. This means if it is stuck doing some long calculation you can be stuck waiting for hours or days even though you can go to a task manager or job scheduler and terminate the job instantly (i.e. alt + ctrl + del in windows or some pkill in linux)
LuckyTran is offline   Reply With Quote
Old   November 16, 2018, 20:21
Rinia
Thanks a lot for your explanation.
It seems that all I can do is waiting.
collection efficiency/ catch ratio m zahid Fluent Multiphase 0 June 19, 2015 06:17
Couldn't start my analysis. (timed out waiting for unlocked lock file) sheonn92 Fidelity CFD 1 May 9, 2015 14:59
waves: model/parameters to catch the breaking JohnAB STAR-CCM+ 0 August 21, 2013 17:53
Catch rate(gm/in2), in DPM Saima FLUENT 1 June 26, 2009 07:18
Help!! Catch the velocity Park. C.Y FLUENT 2 April 30, 2004 06:00
