January 6, 2019, 11:48 |
External fluid flow over air wing
JOHN SHERJY SYRIAC
Rep Power: 8 |
Hi guys
I am trying to simulation external flow over a airwing with fluid ejection from airfoil surface. A small long surface was created on the airwing surface in catia and the model was exported to STARCCM+. The surface is assigned with velocity inlet BC and the air wing with no slip BC. I am not able to get the output. Kindly help me solve the problem Thank you ps: PFA the model screenshot with surface slot |
January 6, 2019, 17:27 |
Rep Power: 24 |
If you want help you need to ask specific questions. What problems are you encountering?
January 6, 2019, 22:36 |
JOHN SHERJY SYRIAC
Rep Power: 8 |
I am not being able to get fluid ejection flow from the small long surface kept at some distance from the trailing edge(marked as pink color in the fig). what boundary condition should i use?
January 7, 2019, 02:01 |
Rep Power: 24 |
I can't really tell you what boundary condition you should use, that will depend on what you're trying to achieve, which I really don't know anything about.
If you want to add flow to the domain at that surface good BC choices would be velocity inlet and mass flow inlet. However what values to use to achieve your goals is something you need to work out. |
Fluid Flow into Still Air from Faucet | bladder1996 | Fluent Multiphase | 2 | January 8, 2018 10:50 |
Fan flow simulation in open air | idiroft | CFX | 5 | June 10, 2014 07:34 |
ansys cfx solver exit with return code 1!!!!! | mhabibnia | CFX | 7 | August 19, 2013 03:53 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
FSI: Pressure and Normal Force don't match with expected values | Geraud | CFX | 6 | August 21, 2012 15:34 |
