February 2, 2019, 01:22 |
Flow injection from 2D airfoil Surface
JOHN SHERJY SYRIAC
Rep Power: 7 |
Hi guys
I am simulating flow over a 2D airfoil in STAR-CCM+. I want to inject fluid from a small portion on the airfoil. For that i created a small patch near the Trailing Edge of the airfoil (giving split command inorder to seperate it from the remaining airfoil.) I have meshed the domain with prism layer,trimmer and surface remesher. The domain taken is C- domain whose picture has been attached. The airfoil is assigned as No-slip BC with the slit as Velocity inlet with 10m/s with the inlet velocity to the outer domain 109m/s. I have tried with mass flow rate BC for the slit but still i am not able to get the outflow from the surface. I am not able the get the desired action. I hereby attach the scalar plot .Kindly help me out to resolve this issue Thanks in advance John |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Airfoil conditions for unsteady flow | Dave | Main CFD Forum | 3 | April 24, 2008 17:11 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
